mahatma
Problem Z Serverem Poczty Connection Time Out W Logach
witam nie wiem co jest grane ale duza czesc poczty nie wychodzi z serwera jest w deffered a w logu mam connection time out?
przewaznie wp.pl ale tez inne adresy?
server w OVH na debianie z VHCS?
gdzie szukac problemu?
log
Apr 21 21:22:39 ns32777 postfix/smtp[5889]: 8612444526: to=<lumbago1@wp.pl>, relay=none, delay=30, status=deferred (connect to mx.wp.pl[212.77.101.4]: Connection timed out)
64 bytes from 212.77.100.101: icmp_seq=0 ttl=121 time=40.5 ms
64 bytes from 212.77.100.101: icmp_seq=1 ttl=121 time=42.1 ms
64 bytes from 212.77.100.101: icmp_seq=2 ttl=121 time=40.7 ms
64 bytes from 212.77.100.101: icmp_seq=3 ttl=121 time=42.4 ms
64 bytes from 212.77.100.101: icmp_seq=4 ttl=121 time=39.8 ms
64 bytes from 212.77.100.101: icmp_seq=5 ttl=121 time=39.1 ms
64 bytes from 212.77.100.101: icmp_seq=6 ttl=121 time=43.0 ms
64 bytes from 212.77.100.101: icmp_seq=7 ttl=121 time=42.0 ms
64 bytes from 212.77.100.101: icmp_seq=8 ttl=121 time=40.6 ms
64 bytes from 212.77.100.101: icmp_seq=9 ttl=121 time=40.6 ms
64 bytes from 212.77.100.101: icmp_seq=10 ttl=121 time=41.8 ms
64 bytes from 212.77.100.101: icmp_seq=11 ttl=121 time=41.3 ms
64 bytes from 212.77.100.101: icmp_seq=12 ttl=121 time=39.6 ms
64 bytes from 212.77.100.101: icmp_seq=13 ttl=121 time=39.6 ms
[1]+ Stopped ping wp.pl
ping mx.wp.pl
PING mx.wp.pl (212.77.101.4): 56 data bytes
64 bytes from 212.77.101.4: icmp_seq=0 ttl=120 time=47.6 ms
64 bytes from 212.77.101.4: icmp_seq=1 ttl=120 time=40.8 ms
64 bytes from 212.77.101.4: icmp_seq=2 ttl=120 time=42.0 ms
64 bytes from 212.77.101.4: icmp_seq=3 ttl=120 time=40.0 ms
64 bytes from 212.77.101.4: icmp_seq=4 ttl=120 time=41.4 ms
traceroute wp.pl
traceroute to wp.pl (212.77.100.101), 30 hops max, 38 byte packets
1 213.251.163.253 (213.251.163.253) 2.587 ms 0.981 ms 0.771 ms
2 p19-7-6k.routers.ovh.net (213.186.32.1) 0.507 ms 0.476 ms 0.472 ms
3 rdb-2-6k.routeurs.ovh.net (213.186.32.42) 0.732 ms 0.777 ms 0.714 ms
4 fra-decix1.gtsce.net (80.81.192.81) 10.413 ms 10.740 ms 10.407 ms
5 plwaw1-p2-2.ipartners.pl (195.39.208.70) 33.707 ms 34.688 ms 195.39.208.106 (195.39.208.106) 34.503 ms
6 koda3-ge0-1-473.net.ipartners.pl (217.153.2.204) 35.716 ms 34.214 ms 34.953 ms
7 217.8.162.50 (217.8.162.50) 41.094 ms 41.186 ms 40.415 ms
8 zew.rtrd2.adm.wp-sa.pl (212.77.105.29) 39.557 ms 40.373 ms 39.753 ms
9 * * *
10 * * *
11 * * *
traceroute mx.wp.pl
traceroute to mx.wp.pl (212.77.101.4), 30 hops max, 38 byte packets
1 213.251.163.253 (213.251.163.253) 1.134 ms 1.270 ms 5.575 ms
2 p19-7-6k.routers.ovh.net (213.186.32.1) 0.944 ms 0.433 ms 0.383 ms
3 rdb-2-6k.routeurs.ovh.net (213.186.32.42) 3.640 ms 3.771 ms 3.254 ms
4 fra-decix1.gtsce.net (80.81.192.81) 24.626 ms 21.848 ms 12.715 ms
5 plwaw1-p2-2.ipartners.pl (195.39.208.70) 36.138 ms 34.671 ms 195.39.208.106 (195.39.208.106) 35.492 ms
6 koda3-ge0-1-473.net.ipartners.pl (217.153.2.204) 35.035 ms 34.444 ms 33.980 ms
7 217.8.162.50 (217.8.162.50) 41.762 ms 39.820 ms 40.879 ms
8 zew.rtrd2.adm.wp-sa.pl (212.77.105.29) 39.728 ms 41.966 ms 40.504 ms
9 * * *
10 *
wyslalem z konta na innym serverze w ovh GP1000 i do wp i onetu doszlo natychmiast
Zbindowalem w main.cf postfixa na stale 1 ip servera zawsze wysylal z 2 i dziala jak talala nie wiem co jest
sprawdzajac w logach problem zaczal sie dzis nie bylo zadnych zmian na serwerze a wczoraj dostarczalo swietnie?
gdzie szukac problemu obydwa ip maja rewersy i nie so listowane jako spamy
Zadzwon do administratora tego serwera, on napewno znajdzie problem i go poprawi.
Gość patrick
linuxowych
linuksowych - slowa sie naprawde odmieniaja.
zastanawiam sie coraz czesciej czy tylko na forach linuxowych dostaje sie takie odpowiedzi?
taka odpowiedz ma Cie naprowadzic na dobra droge.
