Graffiter.
Problem po instalacji pma (nginx + pma)
Cześć. Po instalacji nginx, php5 i innych dodatków (mysql-client, mysql-server, phpmyadmin) skonfigurowałem usługę webową. Serwer wyświetla się poprawnie, wita komunikatem:
http://insane7.pl : Welcome to nginx! a po wejściu w phpinfo, wszystko działa poprawnie - http://insane7.pl/index.php
Po wejściu w panel phpmyadmin, wyskakuje komunikat:
502 Bad Gateway
nginx
cfg sites-availble/default:
# You may add here your
# server {
# statements for each of your virtual hosts to this file
# You should look at the following URL's in order to grasp a solid understanding
# of Nginx configuration files in order to fully unleash the power of Nginx.
# Generally, you will want to move this file somewhere, and start with a clean
# file but keep this around for reference. Or just disable in sites-enabled.
# Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
server {
#listen 80; ## listen for ipv4; this line is default and implied
#listen [::]:80 default ipv6only=on; ## listen for ipv6
root /usr/share/nginx/www;
index index.html index.htm;
# Make site accessible from http://localhost/
server_name insane7.pl;
# pass the PHP scripts to FPM socket
location ~ \.php$ {
try_files $uri =404;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
# NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini
fastcgi_pass php;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME /usr/share/nginx/www$fastcgi_script_name;
fastcgi_param DOCUMENT_ROOT /usr/share/nginx/www;
# send bad requests to 404
fastcgi_intercept_errors on;
include fastcgi_params;
##phpmyadmin:
location /phpmyadmin {
root /usr/share/nginx/www/;
index index.php index.html index.htm;
location ~ ^/phpmyadmin/(.+\.php)$ {
fastcgi_pass 127.0.0.1:9000;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
include /etc/nginx/fastcgi_params;
location ~* ^/phpmyadmin/(.+\.(jpg|jpeg|gif|css|png|js|ico|html|xml|txt))$ {
location /phpMyAdmin {
rewrite ^/* /phpmyadmin last;
##koniecpma
} location / {
# First attempt to serve request as file, then
# as directory, then fall back to index.html
try_files $uri $uri/ /index.html;
# Uncomment to enable naxsi on this location
# include /etc/nginx/naxsi.rules
location /doc/ {
alias /usr/share/doc/;
autoindex on;
allow 127.0.0.1;
deny all;
# Only for nginx-naxsi : process denied requests
#location /RequestDenied {
# For example, return an error code
#return 418;
#error_page 404 /404.html;
# redirect server error pages to the static page /50x.html
#error_page 500 502 503 504 /50x.html;
#location = /50x.html {
# root /usr/share/nginx/www;
# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
#location ~ \.php$ {
# fastcgi_split_path_info ^(.+\.php)(/.+)$;
# # NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini
# # With php5-cgi alone:
# fastcgi_pass 127.0.0.1:9000;
# # With php5-fpm:
# fastcgi_pass unix:/var/run/php5-fpm.sock;
# fastcgi_index index.php;
# include fastcgi_params;
# deny access to .htaccess files, if Apache's document root
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
# another virtual host using mix of IP-, name-, and port-based configuration
#server {
# listen 8000;
# listen somename:8080;
# server_name somename alias another.alias;
# root html;
# index index.html index.htm;
# location / {
# try_files $uri $uri/ /index.html;
# HTTPS server
#server {
# listen 443;
# server_name localhost;
# root html;
# ssl on;
# ssl_certificate cert.pem;
# ssl_certificate_key cert.key;
# ssl_session_timeout 5m;
# ssl_protocols SSLv3 TLSv1;
# ssl_ciphers ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv3:+EXP;
# ssl_prefer_server_ciphers on;
# location / {
cfg nginx.conf:
user www-data;
# As a thumb rule: One per CPU. If you are serving a large amount
# of static files, which requires blocking disk reads, you may want
# to increase this from the number of cpu_cores available on your
# system.
# The maximum number of connections for Nginx is calculated by:
# max_clients = worker_processes * worker_connections
worker_processes 1;
# Maximum file descriptors that can be opened per process
# This should be > worker_connections
worker_rlimit_nofile 8192;
events {
# When you need > 8000 * cpu_cores connections, you start optimizing
# your OS, and this is probably the point at where you hire people
# who are smarter than you, this is *a lot* of requests.
worker_connections 8000;
error_log /var/log/nginx/error.log;
pid /var/run/nginx.pid;
http {
charset utf-8;
# Upstream to abstract back-end connection(s) for PHP
upstream php {
server unix:/tmp/php5-fpm.sock;
# Set the mime-types via the mime.types external file
include mime.types;
# And the fallback mime-type
default_type application/octet-stream;
# Click tracking!
access_log /var/log/nginx/access.log;
# Hide nginx version
server_tokens off;
# ~2 seconds is often enough for HTML/CSS, but connections in
# Nginx are cheap, so generally it's safe to increase it
keepalive_timeout 20;
# You usually want to serve static files with Nginx
sendfile on;
tcp_nopush on; # off may be better for Comet/long-poll stuff
tcp_nodelay off; # on may be better for Comet/long-poll stuff
server_name_in_redirect off;
types_hash_max_size 2048;
gzip on;
gzip_http_version 1.0;
gzip_comp_level 5;
gzip_min_length 512;
gzip_buffers 4 8k;
gzip_proxied any;
gzip_types
# text/html is always compressed by HttpGzipModule
text/css
text/plain
text/x-component
application/javascript
application/json
application/xml
application/xhtml+xml
application/x-font-ttf
application/x-font-opentype
application/vnd.ms-fontobject
image/svg+xml
image/x-icon;
# This should be turned on if you are going to have pre-compressed copies (.gz) of
# static files available. If not it should be left off as it will cause extra I/O
# for the check. It would be better to enable this in a location {} block for
# a specific directory:
# gzip_static on;
gzip_disable "msie6";
gzip_vary on;
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
System operacyjny to Ubuntu 12.04. PS - Nie wiedziałem gdzie ten temat dać, więc dałem tutaj, jeśli moderator uważa że jest źle umiejscowiony, niech go przeniesie, dzięki! :)
Edytowano przez Graffiter. (zobacz historię edycji)
http://www.howtoforge.com/running-phpmyadmin-on-nginx-lemp-on-debian-squeeze-ubuntu-11.04
server {
               root /usr/share/;
                       root /usr/share/;
                       root /usr/share/;
Właśnie to wklejałem z poradnika, spójrz w config.
server {
root /usr/share/;
root /usr/share/;
root /usr/share/;
Taką lokalizację poprawiłem, jak Ty podałeś, bo jeszcze zmieniałem pod siebie.
w jakiej lokalizacji masz phpmyadmin u siebie na serwerze? Według pliku config: root /usr/share/nginx/www; Tyle że go tam nie ma
No niby w /usr/share/phpmyadmin i w /usr/share/nginx/www/phpmyadmin. Ale robiłem wcześniej według: www.lonelycoder.be/nginx-php-fpm-mysql-phpmyadmin-on-ubuntu-12-04/ I tam była jakaś komenda na kopię pliku do /www.
Obecny cfg /default:
##phpmyadmin:
##koniecpma
eh... , jakaś komenda ;) chyba już za stary jestem. Po pierwsze czy po zmianach restartowałeś nowe ustawienia?
service nginx restart + /etc/init.d/nginx reload.
teoretycznie lepiej mieć dostęp do twojego serwera bo pytania obecnie opieram na gdybaniu więc jak to nie problem to proponuje zastosować się dokładnie do poradnika i przeanalizować historię + logi błędów , które dokładnie wskażą tobie ewentualne problemy. Zdecydowanie masz problem ze ścieżką i przy opcji umożliwiającej dostęp do twojego serwera jest to pewnie 20 min roboty.
Jasne, że mam. Przeczytam error.log i wkleję go tutaj w razie coś.
log error.log:
wycinek:
2013/12/01 17:34:28 [error] 3906#0: *1 connect() failed (111: Connection refused) while connecting to upstream, client: 109.207.155.240, server: insane7.pl, request: "GET /phpmyadmin/ HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "insane7.pl"
Przecież error 502 sugeruje, że problem jest między nginxem, a php, a nie phpmyadminem. Nie wiem po kiego grzyba szukacie tam gdzie nie trzeba.
Pewno twój pool php-fpm działa po unix sockecie, a ty na siłę robisz copy-paste'y z socketem tcp.
www.conf z pool.d:
; Start a new pool named 'www'.
; the variable $pool can we used in any directive and will be replaced by the
; pool name ('www' here)
[www]
; Per pool prefix
; It only applies on the following directives:
; - 'slowlog'
; - 'listen' (unixsocket)
; - 'chroot'
; - 'chdir'
; - 'php_values'
; - 'php_admin_values'
; When not set, the global prefix (or /usr) applies instead.
; Note: This directive can also be relative to the global prefix.
; Default Value: none
;prefix = /path/to/pools/$pool
; Unix user/group of processes
; Note: The user is mandatory. If the group is not set, the default user's group
; will be used.
user = www-data
group = www-data
; The address on which to accept FastCGI requests.
; Valid syntaxes are:
; 'ip.add.re.ss:port' - to listen on a TCP socket to a specific address on
; a specific port;
; 'port' - to listen on a TCP socket to all addresses on a
; specific port;
; '/path/to/unix/socket' - to listen on a unix socket.
; Note: This value is mandatory.
listen = /tmp/php5-fpm.sock
; Set listen(2) backlog. A value of '-1' means unlimited.
; Default Value: 128 (-1 on FreeBSD and OpenBSD)
;listen.backlog = -1
; Set permissions for unix socket, if one is used. In Linux, read/write
; permissions must be set in order to allow connections from a web server. Many
; BSD-derived systems allow connections regardless of permissions.
; Default Values: user and group are set as the running user
; mode is set to 0666
;listen.owner = www-data
;listen.group = www-data
;listen.mode = 0666
; List of ipv4 addresses of FastCGI clients which are allowed to connect.
; Equivalent to the FCGI_WEB_SERVER_ADDRS environment variable in the original
; PHP FCGI (5.2.2+). Makes sense only with a tcp listening socket. Each address
; must be separated by a comma. If this value is left blank, connections will be
; accepted from any ip address.
; Default Value: any
;listen.allowed_clients = 127.0.0.1
; Choose how the process manager will control the number of child processes.
; Possible Values:
; static - a fixed number (pm.max_children) of child processes;
; dynamic - the number of child processes are set dynamically based on the
; following directives. With this process management, there will be
; always at least 1 children.
; pm.max_children - the maximum number of children that can
; be alive at the same time.
; pm.start_servers - the number of children created on startup.
; pm.min_spare_servers - the minimum number of children in 'idle'
; state (waiting to process). If the number
; of 'idle' processes is less than this
; number then some children will be created.
; pm.max_spare_servers - the maximum number of children in 'idle'
; of 'idle' processes is greater than this
; number then some children will be killed.
; ondemand - no children are created at startup. Children will be forked when
; new requests will connect. The following parameter are used:
; can be alive at the same time.
; pm.process_idle_timeout - The number of seconds after which
; an idle process will be killed.
pm = dynamic
; The number of child processes to be created when pm is set to 'static' and the
; maximum number of child processes when pm is set to 'dynamic' or 'ondemand'.
; This value sets the limit on the number of simultaneous requests that will be
; served. Equivalent to the ApacheMaxClients directive with mpm_prefork.
; Equivalent to the PHP_FCGI_CHILDREN environment variable in the original PHP
; CGI. The below defaults are based on a server without much resources. Don't
; forget to tweak pm.* to fit your needs.
; Note: Used when pm is set to 'static', 'dynamic' or 'ondemand'
pm.max_children = 10
; The number of child processes created on startup.
; Note: Used only when pm is set to 'dynamic'
; Default Value: min_spare_servers + (max_spare_servers - min_spare_servers) / 2
pm.start_servers = 4
; The desired minimum number of idle server processes.
; Note: Mandatory when pm is set to 'dynamic'
pm.min_spare_servers = 2
; The desired maximum number of idle server processes.
pm.max_spare_servers = 6
; The number of seconds after which an idle process will be killed.
; Note: Used only when pm is set to 'ondemand'
; Default Value: 10s
;pm.process_idle_timeout = 10s;
; The number of requests each child process should execute before respawning.
; This can be useful to work around memory leaks in 3rd party libraries. For
; endless request processing specify '0'. Equivalent to PHP_FCGI_MAX_REQUESTS.
; Default Value: 0
;pm.max_requests = 500
; The URI to view the FPM status page. If this value is not set, no URI will be
; recognized as a status page. It shows the following informations:
; pool - the name of the pool;
; process manager - static, dynamic or ondemand;
; start time - the date and time FPM has started;
; start since - number of seconds since FPM has started;
; accepted conn - the number of request accepted by the pool;
; listen queue - the number of request in the queue of pending
; connections (see backlog in listen(2));
; max listen queue - the maximum number of requests in the queue
; of pending connections since FPM has started;
; listen queue len - the size of the socket queue of pending connections;
; idle processes - the number of idle processes;
; active processes - the number of active processes;
; total processes - the number of idle + active processes;
; max active processes - the maximum number of active processes since FPM
; has started;
; max children reached - number of times, the process limit has been reached,
; when pm tries to start more children (works only for
; pm 'dynamic' and 'ondemand');
; Value are updated in real time.
; Example output:
; pool: www
; process manager: static
; start time: 01/Jul/2011:17:53:49 +0200
; start since: 62636
; accepted conn: 190460
; listen queue: 0
; max listen queue: 1
; listen queue len: 42
; idle processes: 4
; active processes: 11
; total processes: 15
; max active processes: 12
; max children reached: 0
; By default the status page output is formatted as text/plain. Passing either
; 'html', 'xml' or 'json' in the query string will return the corresponding
; output syntax. Example:
; By default the status page only outputs short status. Passing 'full' in the
; query string will also return status for each pool process.
; Example:
; The Full status returns for each process:
; pid - the PID of the process;
; state - the state of the process (Idle, Running, ...);
; start time - the date and time the process has started;
; start since - the number of seconds since the process has started;
; requests - the number of requests the process has served;
; request duration - the duration in µs of the requests;
; request method - the request method (GET, POST, ...);
; request URI - the request URI with the query string;
; content length - the content length of the request (only with POST);
; user - the user (PHP_AUTH_USER) (or '-' if not set);
; script - the main script called (or '-' if not set);
; last request cpu - the %cpu the last request consumed
; it's always 0 if the process is not in Idle state
; because CPU calculation is done when the request
; processing has terminated;
; last request memory - the max amount of memory the last request consumed
; because memory calculation is done when the request
; If the process is in Idle state, then informations are related to the
; last request the process has served. Otherwise informations are related to
; the current request being served.
; Example output:
; pid: 31330
; state: Running
; start since: 63087
; requests: 12808
; request duration: 1250261
; request method: GET
; request URI: /test_mem.php?N=10000
; content length: 0
; user: -
; script: /home/fat/web/docs/php/test_mem.php
; last request cpu: 0.00
; last request memory: 0
; Note: There is a real-time FPM status monitoring sample web page available
; It's available in: ${prefix}/share/fpm/status.html
; Note: The value must start with a leading slash (/). The value can be
; anything, but it may not be a good idea to use the .php extension or it
; may conflict with a real PHP file.
; Default Value: not set
;pm.status_path = /status
; The ping URI to call the monitoring page of FPM. If this value is not set, no
; URI will be recognized as a ping page. This could be used to test from outside
; that FPM is alive and responding, or to
; - create a graph of FPM availability (rrd or such);
; - remove a server from a group if it is not responding (load balancing);
; - trigger alerts for the operating team (24/7).
;ping.path = /ping
; This directive may be used to customize the response of a ping request. The
; response is formatted as text/plain with a 200 response code.
; Default Value: pong
;ping.response = pong
; The access log file
; Default: not set
;access.log = log/$pool.access.log
; The access log format.
; The following syntax is allowed
; %%: the '%' character
; %C: %CPU used by the request
; it can accept the following format:
; - %{user}C for user CPU only
; - %{system}C for system CPU only
; - %{total}C for user + system CPU (default)
; %d: time taken to serve the request
; - %{seconds}d (default)
; - %{miliseconds}d
; - %{mili}d
; - %{microseconds}d
; - %{micro}d
; %e: an environment variable (same as $_ENV or $_SERVER)
; it must be associated with embraces to specify the name of the env
; variable. Some exemples:
; - server specifics like: %{REQUEST_METHOD}e or %{SERVER_PROTOCOL}e
; - HTTP headers like: %{HTTP_HOST}e or %{HTTP_USER_AGENT}e
; %f: script filename
; %l: content-length of the request (for POST request only)
; %m: request method
; %M: peak of memory allocated by PHP
; - %{bytes}M (default)
; - %{kilobytes}M
; - %{kilo}M
; - %{megabytes}M
; - %{mega}M
; %n: pool name
; %o: ouput header
; it must be associated with embraces to specify the name of the header:
; - %{Content-Type}o
; - %{X-Powered-By}o
; - %{Transfert-Encoding}o
; %p: PID of the child that serviced the request
; %P: PID of the parent of the child that serviced the request
; %q: the query string
; %Q: the '?' character if query string exists
; %r: the request URI (without the query string, see %q and %Q)
; %R: remote IP address
; %s: status (response code)
; %t: server time the request was received
; it can accept a strftime(3) format:
; %d/%b/%Y:%H:%M:%S %z (default)
; %T: time the log has been written (the request has finished)
; %u: remote user
; Default: "%R - %u %t \"%m %r\" %s"
;access.format = %R - %u %t "%m %r%Q%q" %s %f %{mili}d %{kilo}M %C%%
; The log file for slow requests
; Note: slowlog is mandatory if request_slowlog_timeout is set
;slowlog = log/$pool.log.slow
; The timeout for serving a single request after which a PHP backtrace will be
; dumped to the 'slowlog' file. A value of '0s' means 'off'.
; Available units: s(econds)(default), m(inutes), h(ours), or d(ays)
; Default Value: 0
;request_slowlog_timeout = 0
; The timeout for serving a single request after which the worker process will
; be killed. This option should be used when the 'max_execution_time' ini option
; does not stop script execution for some reason. A value of '0' means 'off'.
; Default Value: 0
;request_terminate_timeout = 0
; Set open file descriptor rlimit.
; Default Value: system defined value
;rlimit_files = 1024
; Set max core size rlimit.
; Possible Values: 'unlimited' or an integer greater or equal to 0
;rlimit_core = 0
; Chroot to this directory at the start. This value must be defined as an
; absolute path. When this value is not set, chroot is not used.
; Note: you can prefix with '$prefix' to chroot to the pool prefix or one
; of its subdirectories. If the pool prefix is not set, the global prefix
; will be used instead.
; Note: chrooting is a great security feature and should be used whenever
; possible. However, all PHP paths will be relative to the chroot
; (error_log, sessions.save_path, ...).
;chroot =
; Chdir to this directory at the start.
; Note: relative path can be used.
; Default Value: current directory or / when chroot
chdir = /
; Redirect worker stdout and stderr into main error log. If not set, stdout and
; stderr will be redirected to /dev/null according to FastCGI specs.
; Note: on highloaded environement, this can cause some delay in the page
; process time (several ms).
; Default Value: no
;catch_workers_output = yes
; Limits the extensions of the main script FPM will allow to parse. This can
; prevent configuration mistakes on the web server side. You should only limit
; FPM to .php extensions to prevent malicious users to use other extensions to
; exectute php code.
; Note: set an empty value to allow all extensions.
; Default Value: .php
;security.limit_extensions = .php .php3 .php4 .php5
; Pass environment variables like LD_LIBRARY_PATH. All $VARIABLEs are taken from
; the current environment.
; Default Value: clean env
;env[HOSTNAME] = $HOSTNAME
;env[PATH] = /usr/local/bin:/usr/bin:/bin
;env[TMP] = /tmp
;env[TMPDIR] = /tmp
;env[TEMP] = /tmp
; Additional php.ini defines, specific to this pool of workers. These settings
; overwrite the values previously defined in the php.ini. The directives are the
; same as the PHP SAPI:
; php_value/php_flag - you can set classic ini defines which can
; be overwritten from PHP call 'ini_set'.
; php_admin_value/php_admin_flag - these directives won't be overwritten by
; PHP call 'ini_set'
; For php_*flag, valid values are on, off, 1, 0, true, false, yes or no.
; Defining 'extension' will load the corresponding shared extension from
; extension_dir. Defining 'disable_functions' or 'disable_classes' will not
; overwrite previously defined php.ini values, but will append the new value
; instead.
; Note: path INI options can be relative and will be expanded with the prefix
; (pool, global or /usr)
; Default Value: nothing is defined by default except the values in php.ini and
; specified at startup with the -d argument
;php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f www@my.domain.com
;php_flag[display_errors] = off
;php_admin_value[error_log] = /var/log/fpm-php.www.log
;php_admin_flag[log_errors] = on
;php_admin_value[memory_limit] = 32M
Wszystko tutaj się zgadza?
Dobra, dzięki - dałem radę :)
