peres.pro
Aktualizacja nginxa do 1.5.6 i problem z zbindowanym portem
Zaktualizowałem sobie nginxa do 1.5.6, i teraz jest mały problem, a mianowicie gdy wykonuje service nginx restart to wyskakuje następujący błąd:
Restarting nginx: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
nginx.
root@lanceq:~#
Zawartość nginx.conf:
http://wklej.to/uz3AF
dodatkowo jeszcze kilka komend aby sprawdzić port:
root@lanceq:~# netstat -lnp | grep 0.0.0.0:80
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      2759/nginx
root@lanceq:~# fuser 80/tcp
80/tcp:               2759  2765
root@lanceq:~# lsof +M -i4
COMMAND    PID    USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
dhclient  1617    root    5u  IPv4   5039      0t0  UDP *:bootpc
dhclient  1617    root   20u  IPv4   4999      0t0  UDP *:65425
rpcbind   1708    root    6u  IPv4   5563      0t0  UDP *:sunrpc[portmapper]
rpcbind   1708    root    7u  IPv4   5566      0t0  UDP *:npmp-gui
rpcbind   1708    root    8u  IPv4   5567      0t0  TCP *:sunrpc[portmapper] (LI
rpc.statd 1739   statd    4w  IPv4   5608      0t0  UDP localhost:643
rpc.statd 1739   statd    7u  IPv4   5615      0t0  UDP *:46344[status]
rpc.statd 1739   statd    8u  IPv4   5619      0t0  TCP *:56583[status] (LISTEN)
named     2173    bind   21u  IPv4   6260      0t0  TCP localhost:domain (LISTEN
named     2173    bind   22u  IPv4   6262      0t0  TCP hosted-by.slaskdatacente
named     2173    bind   23u  IPv4   5936      0t0  TCP localhost:953 (LISTEN)
named     2173    bind  513u  IPv4   6259      0t0  UDP localhost:domain
named     2173    bind  514u  IPv4   6261      0t0  UDP hosted-by.slaskdatacente
memcached 2641  nobody   26u  IPv4   6113      0t0  TCP localhost:11211 (LISTEN)
memcached 2641  nobody   27u  IPv4   6115      0t0  UDP localhost:11211
/usr/sbin 2725  amavis    5u  IPv4   7175      0t0  TCP localhost:10024 (LISTEN)
nginx     2759    root    6u  IPv4   6634      0t0  TCP *:http (LISTEN)
nginx     2765  nobody    6u  IPv4   6634      0t0  TCP *:http (LISTEN)
sshd      3089    root    3u  IPv4   7458      0t0  TCP *:ssh (LISTEN)
mysqld    3113   mysql   10u  IPv4   7486      0t0  TCP *:mysql (LISTEN)
mysqld    3113   mysql   33u  IPv4   8727      0t0  TCP localhost:mysql->localho
/usr/sbin 3138  amavis    5u  IPv4   7175      0t0  TCP localhost:10024 (LISTEN)
/usr/sbin 3138  amavis   11u  IPv4   8726      0t0  TCP localhost:54709->localho
/usr/sbin 3138  amavis   12u  IPv4   8736      0t0  TCP localhost:47561->localho
/usr/sbin 3139  amavis    5u  IPv4   7175      0t0  TCP localhost:10024 (LISTEN)
dovecot   3237    root   22u  IPv4   7706      0t0  TCP *:pop3 (LISTEN)
dovecot   3237    root   24u  IPv4   7708      0t0  TCP *:pop3s (LISTEN)
dovecot   3237    root   32u  IPv4   7722      0t0  TCP *:imap2 (LISTEN)
dovecot   3237    root   34u  IPv4   7724      0t0  TCP *:imaps (LISTEN)
master    3713    root   12u  IPv4   6912      0t0  TCP *:smtp (LISTEN)
master    3713    root  110u  IPv4   7012      0t0  TCP localhost:10025 (LISTEN)
sshd      3764    root    3r  IPv4   8455      0t0  TCP hosted-by.slaskdatacente
ntpd      3770     ntp   16u  IPv4   7070      0t0  UDP *:ntp
ntpd      3770     ntp   18u  IPv4   7077      0t0  UDP localhost:ntp
ntpd      3770     ntp   19u  IPv4   7078      0t0  UDP hosted-by.slaskdatacente
smtpd     3887 postfix    6u  IPv4   7012      0t0  TCP localhost:10025 (LISTEN)
sshd      3894    root    3r  IPv4   8784      0t0  TCP hosted-by.slaskdatacente
smtpd     4029 postfix    6u  IPv4   6912      0t0  TCP *:smtp (LISTEN)
Edytowano przez lanceq (zobacz historię edycji)
Patrys, dzięki za szybką odpowiedź, po wykonaniu komendy fuser -kill 80/tcp zabija, restartuje nginxa - działa, restartuje nginxa ponownie i dalej to samo.
Więc to raczej nie jest wyjście, po reebocie jest to samo, nie zbyt wiem jak to naprawić, liczę na pomoc.
Aha i nie wiem czy to może być jakimś powodem ale skompilowałem tego najnowszego nginxa wraz z mod_pagespeed.
Może zrobiłem coś źle przy kompilacji?
root@lanceq:~# nginx -V
nginx version: nginx/1.5.6
built by gcc 4.7.2 (Debian 4.7.2-5)
configure arguments: --add-module=/root/ngx_pagespeed-1.7.30.1-beta
root@lanceq:~#
tutaj zawartość /etc/init.d/nginx
#!/bin/sh
### BEGIN INIT INFO
# Provides:          nginx
# Required-Start:    $local_fs $remote_fs $network $syslog
# Required-Stop:     $local_fs $remote_fs $network $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: starts the nginx web server
# Description:       starts nginx using start-stop-daemon
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/usr/sbin/nginx
NAME=nginx
DESC=nginx
# Include nginx defaults if available
if [ -f /etc/default/nginx ]; then
	. /etc/default/nginx
fi
test -x $DAEMON || exit 0
set -e
. /lib/lsb/init-functions
test_nginx_config() {
	if $DAEMON -t $DAEMON_OPTS >/dev/null 2>&1; then
		return 0
	else
		return $?
	fi
case "$1" in
	start)
		echo -n "Starting $DESC: "
		test_nginx_config
		# Check if the ULIMIT is set in /etc/default/nginx
		if [ -n "$ULIMIT" ]; then
			# Set the ulimits
			ulimit $ULIMIT
		fi
		start-stop-daemon --start --quiet --pidfile /var/run/$NAME.pid \
		    --exec $DAEMON -- $DAEMON_OPTS || true
		echo "$NAME."
	stop)
		echo -n "Stopping $DESC: "
		start-stop-daemon --stop --quiet --pidfile /var/run/$NAME.pid \
		    --exec $DAEMON || true
		echo "$NAME."
	restart|force-reload)
		echo -n "Restarting $DESC: "
		start-stop-daemon --stop --quiet --pidfile \
		    /var/run/$NAME.pid --exec $DAEMON || true
		sleep 1
		test_nginx_config
			# Set the ulimits
			ulimit $ULIMIT
		fi
		start-stop-daemon --start --quiet --pidfile \
		    /var/run/$NAME.pid --exec $DAEMON -- $DAEMON_OPTS || true
		echo "$NAME."
	reload)
		echo -n "Reloading $DESC configuration: "
		test_nginx_config
		start-stop-daemon --stop --signal HUP --quiet --pidfile /var/run/$NAME.pid \
		echo "$NAME."
	configtest|testconfig)
		echo -n "Testing $DESC configuration: "
		if test_nginx_config; then
			echo "$NAME."
		else
			exit $?
		fi
	status)
		status_of_proc -p /var/run/$NAME.pid "$DAEMON" nginx && exit 0 || exit $?
		echo "Usage: $NAME {start|stop|restart|reload|force-reload|status|configtest}" >&2
		exit 1
esac
exit 0
Gość patrys
Sprawdź ścieżkę binarki nginx'a czy zgadza się z starterem i czy po wywołaniu parametru 'start' tworzy się plik .pid oraz czy przy 'stop' jest usuwany.
Prawdopodobnie masz 2 nginx'y w systemie. Jeden instalowany z apt-get/aptitude, a drugi skompilowany. Musisz poprawić ścieżki w /etc/init.d/nginx
