Keaman
httpd (pid 3281?) not running
ostatnio zachciało mi się zainstalować jakiś panel do zarządzania serwerem, więc zainstalowałem ispcp. Jednak po instalacji wszytko mi padło, oto co dostaje przy próbuje restartu apache:
 sudo /etc/init.d/apache2 restart
Forcing reload of web server (apache2)...httpd (pid 3281?) not running
Logi z apahce/error.log:
Tue Oct 13 19:20:24 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:23:31 2009] [notice] FastCGI: process manager initialized (pid 20455)
[Tue Oct 13 19:23:31 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:23:32 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:23:33 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:23:34 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:23:45 2009] [notice] FastCGI: process manager initialized (pid 21653)
[Tue Oct 13 19:23:45 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 13 19:23:45 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:23:46 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:23:48 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:32:52 2009] [notice] FastCGI: process manager initialized (pid 7187)
[Tue Oct 13 19:32:52 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 13 19:32:52 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:32:53 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:32:54 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:32:55 2009] [alert] No active workers found... Apache is exiting!
[Tue Oct 13 19:42:27 2009] [notice] FastCGI: process manager initialized (pid 30041)
[Tue Oct 13 19:42:27 2009] [warn] pid file /var/run/apache2.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Oct 13 19:42:27 2009] [notice] Apache/2.2.3 (Debian) mod_fastcgi/2.4.2 mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming nor$
[Tue Oct 13 19:42:28 2009] [alert] (12)Cannot allocate memory: apr_thread_create: unable to create worker thread
[Tue Oct 13 19:42:30 2009] [alert] No active workers found... Apache is exiting!
System to Debian 4
Jakieś sugestie?
Dowiedz się, czemu nie może zaalokować pamięci... Czyżby się skończyła po prostu?
Dziękuje, za trafną odpowiedz.
Odinstalowałem ispcp jednak dalej to samo się dzieje i to samo w logach. Pomyślałem, ze może bind się nie odinstalował razem z ispcp i dalej pamięć wcina ale:
sudo apt-get --purge remove bind
Reading package lists... Done
Building dependency tree... Done
Package bind is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
hmmm...??
Edit.
Może to się przyda;
ps -e -orss=,args= | sort -b -k1,1n | pr -TW$COLUMNS
 272 /usr/lib/courier/courier-authlib/authdaemond
 324 /usr/sbin/courierlogger courierpop3login
 328 /usr/sbin/courierlogger -pid=/var/run/courier/imapd.pid -start -name=imapd /usr/sbin/couriertcpd -address=0 -maxprocs=40 -maxperip=20 -
 376 /sbin/portmap
 404 /usr/sbin/courierlogger -pid=/var/run/courier/authdaemon/pid -start /usr/lib/courier/courier-authlib/authdaemond
 420 /usr/sbin/atd
 512 logger -p daemon.err -t mysqld_safe -i -t mysqld
 512 /usr/sbin/couriertcpd -pid=/var/run/courier/pop3d.pid -stderrlogger=/usr/sbin/courierlogger -maxprocs=40 -maxperip=4 -nodnslookup -noid
 548 /usr/sbin/couriertcpd -address=0 -maxprocs=40 -maxperip=20 -nodnslookup -noidentlookup 143 /usr/lib/courier/courier/imaplogin /usr/bin/
 560 /sbin/syslogd
 572 sort -b -k1,1n
 576 /usr/sbin/inetd
 612 /usr/sbin/famd -T 0
 628 /usr/lib/courier/courier-authlib/authdaemond
 660 pr -TW141
 668 init [2]
 704 /usr/bin/freshclam -d --quiet
 804 ps -e -orss=,args=
 896 /usr/sbin/cron
1092 /usr/sbin/sshd
1332 /bin/sh /usr/bin/mysqld_safe
1568 sshd: tomasz@pts/0
1628 /usr/lib/postfix/master
1632 pickup -l -t fifo -u -c
1704 qmgr -l -t fifo -u
2316 sshd: tomasz [priv]
3044 -bash
7360 policyd-weight (cache)
7688 policyd-weight (master)
7880 /usr/sbin/postgrey --pidfile=/var/run/postgrey.pid --daemonize --inet=127.0.0.1:60000
17716 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/run/mysqld/mysqld.pid --skip-external-locking --p
28540 /usr/sbin/clamd
To oczywiście wyżeracze pamięci na teraz, przy próbie
pamięci rzeczywiście zaczyna brakować, sprawdziłem.
Co to może być?
<!--c1--><div class='codetop'>KOD</div><div class='codemain'><!--ec1-->
[Tue Oct 13 19:42:30 2009] [alert] No active workers found... Apache is exiting!<!--c2--></div><!--ec2-->
System to Debian 4
Jakieś sugestie?
sudo apt-get install apache2-mpm-prefork
przy mysql stop:
free -m
	total 	used 	free 	shared	buffers 	cached
Mem: 	384 	67 	316 	0 	0 	0
-/+ buffers/cache: 	67 	316
Swap: 	0 	0 	0
przy włączonym mysql:
Mem: 	384 	187 	196 	0 	0 	0
-/+ buffers/cache: 	187 	196
Swap: 	0 	0 	0
Przy wyłączonym mysql przy restarcie apache:
Forcing reload of web server (apache2)...httpd (pid 30566?) not running
Dodam jeszcze że:
sudo /etc/init.d/apache2 start
Starting web server (apache2)....
Forcing reload of web server (apache2)...httpd (pid 3182?) not running
Edit.
Sorki za post pod postem, z jakiś nie znanych dla mnie powodów nie mogłem edytować wcześniejszego posta.
Udało mi się odpalić apache przy wyłączonym mysql, o ale:
free -m
Mem: 	384 	305 	78 	0 	0 	0
-/+ buffers/cache: 	305 	78
Swap: 	0 	0 	0
Co do sudo apt-get install apache2-mpm-prefork to:
The following packages will be REMOVED:
apache2-mpm-worker
The following NEW packages will be installed:
apache2-mpm-prefork
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
Need to get 0B/420kB of archives.
After unpacking 8192B disk space will be freed.
Do you want to continue [Y/n]? y
dpkg: apache2-mpm-worker: dependency problems, but removing anyway as you request:
apache2 depends on apache2-mpm-worker (>= 2.2.3-4+etch10) | apache2-mpm-prefork (>= 2.2.3-4+etch10) | apache2-mpm-event (>= 2.2.3-4+etch10); however:
Package apache2-mpm-worker is to be removed.
Package apache2-mpm-prefork is not installed.
Package apache2-mpm-event is not installed.
(Reading database ... 33078 files and directories currently installed.)
Removing apache2-mpm-worker ...
dpkg: error processing apache2-mpm-worker (--remove):
[b]fork failed: Cannot allocate memory[/b]
dpkg: error while cleaning up:
Errors were encountered while processing:
apache2-mpm-worker
Processing was halted because there were too many errors.
Nie masz swap'u (to VPS)?
Zapchane katalogi tymczasowe typu tmp/
Może spróbuj go zrestartować i wtedy zobacz
Być może jest od za słaby..
Tak VPS,
zrestartowanie niestety nie pomaga.
Ogólnie przed instalacją ISPCP wszystko było oki, z tego co pamiętam luzem zostawało mi 100mb wolnego ramu. Po instalacji ISPCP zaczęły dziać się te kwiatki a deinstalacja ISPCP nic nie zmieniła.
Edit.
free -m
Swap: 	0 	0 	0
apache2-mpm-worker
apache2-mpm-prefork
apache2-mpm-worker
Masz mizerną ilość pamięci w dodatku nie masz swapa. Sorry Winnetou, z gówna bicza nie ukręcisz. Wrzuć apache'a 1.3 jakiegoś starego php i sqlite'a zamiast mysqla to może ci to ruszy.
Tak, teraz to wiem, ogólnie wszystko chodziło oki, dopóki nie zachciałem sobie ułatwiać życia instalując ISPCP aby zarządzać wszystkim z poziomu przeglądarki. Deinstalacja ISPCP nie pomogła, jak widać wcina za dużo ramu choć wcześniej wszystko było oki. Jaka może być tego przyczyna? Reinstalacja to ostateczność, bo na tym VPSie dzałają a właściwie działały mi serwisy, co prawda mam kopie baz danych, jednak wolał bym uniknąć reinstalacji.
Zatrzymaj wszystkie usługi które żrą pamięc - apache, mysql, ftp, pocztę itp... Otwórz drugi terminal i wpisz "top".
Naciśnij "M", to posortuje ci procesy według zużycia RAM-u. Potem po kolei odpalaj usługi i obserwuj przy której znacząco skoczy zużycie pamięci.
Potem trzeba ustawić na stare wartości to co ci przekonfigurował ISP-CP.
No wiec sprawa wygląda tak, apache2 zużywa prawie 250mb:
top:
 PID USER 	PR NI VIRT RES SHR S %CPU %MEM	TIME+ COMMAND
1 root 	15 0 1948 664 572 S 0.0 0.2 0:00.13 init
5645 tomasz	15 0 2232 1092 856 T 0.0 0.3 0:00.00 top
13517 root 	18 0 11436 3304 1928 S 0.0 0.8 0:00.00 apache2
13518 www-data 25 0 10876 2164 792 S 0.0 0.6 0:00.00 apache2
13520 www-data 15 0 11192 2028 672 S 0.0 0.5 0:00.00 apache2
13521 www-data 25 0 235m 4132 2088 S 0.0 1.1 0:00.00 apache2
13980 tomasz	15 0 2232 1108 860 R 0.0 0.3 0:00.27 top
24000 daemon	18 0 1688 372 280 S 0.0 0.1 0:00.00 portmap
24130 root 	15 0 1628 560 456 S 0.0 0.1 0:00.00 syslogd
24349 polw 	18 0 9792 7688 1188 S 0.0 2.0 0:00.00 policyd-weight
24350 polw 	18 0 9792 7360 856 S 0.0 1.9 0:00.00 policyd-weight
24353 postgrey 19 0 10644 7864 2388 S 0.0 2.0 0:00.00 postgrey
24515 clamav	15 0 5492 700 404 S 0.0 0.2 0:00.00 freshclam
24523 root 	18 0 1752 404 328 S 0.0 0.1 0:00.00 courierlogger
25601 root 	18 0 1952 628 504 S 0.0 0.2 0:00.00 authdaemond
25623 root 	18 0 1952 284 160 S 0.0 0.1 0:00.00 authdaemond
25625 root 	25 0 1752 328 260 S 0.0 0.1 0:00.00 courierlogger
25627 root 	18 0 1952 284 160 S 0.0 0.1 0:00.00 authdaemond
25628 root 	18 0 1952 284 160 S 0.0 0.1 0:00.00 authdaemond
25629 root 	18 0 1952 284 160 S 0.0 0.1 0:00.00 authdaemond
25633 root 	18 0 1952 284 160 S 0.0 0.1 0:00.00 authdaemond
25634 root 	25 0 1856 544 460 S 0.0 0.1 0:00.00 couriertcpd
25654 root 	25 0 1856 508 424 S 0.0 0.1 0:00.00 couriertcpd
25660 root 	25 0 1620 324 260 S 0.0 0.1 0:00.00 courierlogger
25668 root 	18 0 1752 572 480 S 0.0 0.1 0:00.00 inetd
25870 root 	15 0 4816 1624 1308 S 0.0 0.4 0:00.00 master
25876 postfix 18 0 4824 1636 1320 S 0.0 0.4 0:00.00 pickup
25877 postfix 18 0 4860 1704 1384 S 0.0 0.4 0:00.00 qmgr
25898 root 	15 0 4932 1096 760 S 0.0 0.3 0:00.00 sshd
25953 root 	21 0 3020 612 452 S 0.0 0.2 0:00.00 famd
27834 daemon	23 0 1832 424 300 S 0.0 0.1 0:00.00 atd
27849 root 	17 0 2196 892 708 S 0.0 0.2 0:00.00 cron
28213 root 	16 0 7704 2316 1884 S 0.0 0.6 0:00.02 sshd
28311 tomasz	15 0 7864 1604 1132 R 0.0 0.4 0:00.05 sshd
28312 tomasz	15 0 5732 3020 1408 S 0.0 0.8 0:00.13 bash
28477 tomasz	15 0 2232 1092 856 T 0.0 0.3 0:00.00 top
30230 tomasz	15 0 2232 1100 856 T 0.0 0.3 0:00.01 top
32518 tomasz	15 0 2232 1088 856 T 0.0 0.3 0:00.00 top
A oto pliki edytowane przez ISP-CP, sporo tego więc może jakieś propozycje co do zmian?? :
sudo hg status
? apache2/mods-available/cband.conf
? apache2/mods-available/cband.load
? apache2/mods-available/fastcgi.conf
? apache2/mods-available/fastcgi.load
? apache2/mods-available/fcgid.conf
? apache2/mods-available/fcgid.load
? apache2/mods-available/fcgid_ispcp.conf
? apache2/mods-available/fcgid_ispcp.load
? apache2/mods-available/proxy.conf.orig
? apache2/sites-available/01_awstats.conf
? bind/db.0
? bind/db.127
? bind/db.255
? bind/db.empty
? bind/db.local
? bind/db.root
? bind/named.conf
? bind/named.conf.local
? bind/named.conf.options
? bind/rndc.key
? bind/zones.rfc1918
? chkrootkit.conf
? courier/authdaemonrc
? courier/authmodulelist
? courier/imapd
? courier/maildrop
? courier/pop3d
? courier/userdb
? courier/userdb.dat
? courier/userdbshadow.dat
? cron.daily/chkrootkit
? cron.daily/rkhunter
? cron.weekly/rkhunter
? default/bind9
? default/courier
? default/portmap
? default/postgrey
? default/rkhunter
? default/saslauthd
? dictionaries-common/ispell-default
? emacs/site-start.d/50dictionaries-common.el
? fam.conf
? group-.orig
? group.orig
? gshadow-.orig
? gshadow.orig
? hosts.bkp
? hosts.orig
? init.d/bind9
? init.d/courier-authdaemon
? init.d/courier-imap
? init.d/courier-pop
? init.d/fam
? init.d/policyd-weight
? init.d/portmap
? init.d/postgrey
? init.d/saslauthd
? ispcp/apache/00_master.conf
? ispcp/apache/01_awstats.conf
? ispcp/apache/backup/empty-file
? ispcp/apache/backup/fastcgi_ispcp.conf.ispcp
? ispcp/apache/backup/fcgid_ispcp.conf.ispcp
? ispcp/apache/backup/proxy.conf
? ispcp/apache/httpd.conf
? ispcp/apache/parts/als_awstats_b.tpl
? ispcp/apache/parts/als_awstats_dynamic_entry.tpl
? ispcp/apache/parts/als_awstats_e.tpl
? ispcp/apache/parts/als_awstats_static_entry.tpl
? ispcp/apache/parts/als_b.tpl
? ispcp/apache/parts/als_cgi_b.tpl
? ispcp/apache/parts/als_cgi_e.tpl
? ispcp/apache/parts/als_cgi_entry.tpl
? ispcp/apache/parts/als_e.tpl
? ispcp/apache/parts/als_entry.tpl
? ispcp/apache/parts/als_php2_b.tpl
? ispcp/apache/parts/als_php2_e.tpl
? ispcp/apache/parts/als_php2_entry.tpl
? ispcp/apache/parts/als_php_b.tpl
? ispcp/apache/parts/als_php_e.tpl
? ispcp/apache/parts/als_php_entry.tpl
? ispcp/apache/parts/als_rdr_b.tpl
? ispcp/apache/parts/als_rdr_e.tpl
? ispcp/apache/parts/als_rdr_entry.tpl
? ispcp/apache/parts/cfg_b.tpl
? ispcp/apache/parts/cfg_e.tpl
? ispcp/apache/parts/custom.conf.tpl
? ispcp/apache/parts/dg_b.tpl
? ispcp/apache/parts/dg_e.tpl
? ispcp/apache/parts/dg_entry.tpl
? ispcp/apache/parts/dmn_awstats_b.tpl
? ispcp/apache/parts/dmn_awstats_dynamic_entry.tpl
? ispcp/apache/parts/dmn_awstats_e.tpl
? ispcp/apache/parts/dmn_awstats_static_entry.tpl
? ispcp/apache/parts/dmn_b.tpl
? ispcp/apache/parts/dmn_cgi_b.tpl
? ispcp/apache/parts/dmn_cgi_e.tpl
? ispcp/apache/parts/dmn_cgi_entry.tpl
? ispcp/apache/parts/dmn_e.tpl
? ispcp/apache/parts/dmn_entry.tpl
? ispcp/apache/parts/dmn_php2_b.tpl
? ispcp/apache/parts/dmn_php2_e.tpl
? ispcp/apache/parts/dmn_php2_entry.tpl
? ispcp/apache/parts/dmn_php_b.tpl
? ispcp/apache/parts/dmn_php_e.tpl
? ispcp/apache/parts/dmn_php_entry.tpl
? ispcp/apache/parts/ispcp_base.tpl
? ispcp/apache/parts/sub_b.tpl
? ispcp/apache/parts/sub_cgi_b.tpl
? ispcp/apache/parts/sub_cgi_e.tpl
? ispcp/apache/parts/sub_cgi_entry.tpl
? ispcp/apache/parts/sub_e.tpl
? ispcp/apache/parts/sub_entry.tpl
? ispcp/apache/parts/sub_php2_b.tpl
? ispcp/apache/parts/sub_php2_e.tpl
? ispcp/apache/parts/sub_php2_entry.tpl
? ispcp/apache/parts/sub_php_b.tpl
? ispcp/apache/parts/sub_php_e.tpl
? ispcp/apache/parts/sub_php_entry.tpl
? ispcp/apache/parts/vh_b.tpl
? ispcp/apache/parts/vh_e.tpl
? ispcp/apache/parts/vh_entry.tpl
? ispcp/apache/working/fastcgi_ispcp.conf
? ispcp/apache/working/fcgid_ispcp.conf
? ispcp/apache/working/ispcp.conf
? ispcp/awstats/awstats.ispcp_tpl.conf
? ispcp/bind/backup/empty-file
? ispcp/bind/backup/named.conf.1255457775
? ispcp/bind/backup/named.conf.1255458277
? ispcp/bind/backup/named.conf.1255459443
? ispcp/bind/named.conf
? ispcp/bind/parts/cfg_dta_b.tpl
? ispcp/bind/parts/cfg_dta_e.tpl
? ispcp/bind/parts/cfg_entry.tpl
? ispcp/bind/parts/cfg_entry_b.tpl
? ispcp/bind/parts/cfg_entry_e.tpl
? ispcp/bind/parts/db_dns2_b.tpl
? ispcp/bind/parts/db_dns2_e.tpl
? ispcp/bind/parts/db_e.tpl
? ispcp/bind/parts/db_master_e.tpl
? ispcp/bind/parts/db_sub_entry.tpl
? ispcp/bind/parts/db_sub_entry_b.tpl
? ispcp/bind/parts/db_sub_entry_e.tpl
? ispcp/bind/parts/db_time_b.tpl
? ispcp/bind/parts/db_time_e.tpl
? ispcp/bind/working/admin.ibochnia.pl.db
? ispcp/bind/working/named.conf
? ispcp/courier/backup/authdaemonrc.system
? ispcp/courier/backup/empty-file
? ispcp/courier/backup/userdb.system
? ispcp/courier/userdb
? ispcp/courier/working/userdb
? ispcp/cron.d/backup/empty-file
? ispcp/cron.d/backup/ispcp
? ispcp/cron.d/ispcp
? ispcp/cron.d/parts/als_awstats_b.tpl
? ispcp/cron.d/parts/als_awstats_e.tpl
? ispcp/cron.d/parts/als_awstats_entry.tpl
? ispcp/cron.d/parts/dmn_awstats_b.tpl
? ispcp/cron.d/parts/dmn_awstats_e.tpl
? ispcp/cron.d/parts/dmn_awstats_entry.tpl
? ispcp/cron.d/parts/dmn_bk_b.tpl
? ispcp/cron.d/parts/dmn_bk_e.tpl
? ispcp/cron.d/parts/dmn_bk_entry.tpl
? ispcp/cron.d/parts/dmn_custom_b.tpl
? ispcp/cron.d/parts/dmn_custom_e.tpl
? ispcp/cron.d/parts/dmn_custom_entry.tpl
? ispcp/cron.d/parts/dt_b.tpl
? ispcp/cron.d/parts/dt_e.tpl
? ispcp/cron.d/working/ispcp
? ispcp/database/database.sql
? ispcp/database/languages.sql
? ispcp/fcgi/backup/empty-file
? ispcp/fcgi/backup/php5-fcgi-starter.ispcp
? ispcp/fcgi/parts/master/php4-fcgi-starter.tpl
? ispcp/fcgi/parts/master/php4/php.ini
? ispcp/fcgi/parts/master/php5-fcgi-starter.tpl
? ispcp/fcgi/parts/master/php5/php.ini
? ispcp/fcgi/parts/php4-fcgi-starter.tpl
? ispcp/fcgi/parts/php4/php.ini
? ispcp/fcgi/parts/php5-fcgi-starter.tpl
? ispcp/fcgi/parts/php5/php.ini
? ispcp/fcgi/working/empty-file
? ispcp/ispcp.conf
? ispcp/postfix/backup/empty-file
? ispcp/postfix/ispcp/aliases
? ispcp/postfix/ispcp/domains
? ispcp/postfix/ispcp/mailboxes
? ispcp/postfix/ispcp/sender-access
? ispcp/postfix/ispcp/transport
? ispcp/postfix/main.cf
? ispcp/postfix/master.cf
? ispcp/postfix/parts/empty-file
? ispcp/postfix/working/aliases
? ispcp/postfix/working/domains
? ispcp/postfix/working/mailboxes
? ispcp/postfix/working/sender-access
? ispcp/postfix/working/transport
? ispcp/proftpd/backup/empty-file
? ispcp/proftpd/parts/proftpd.conf.tpl
? ispcp/proftpd/proftpd.conf
? ispcp/proftpd/working/empty-file
? logcheck/ignore.d.server/courier-imap
? logcheck/ignore.d.server/courier-pop
? logcheck/ignore.d.server/postgrey
? logcheck/violations.ignore.d/courier-imap
? logcheck/violations.ignore.d/courier-pop
? logcheck/violations.ignore.d/postgrey
? logrotate.d/apache2.orig
? logrotate.d/ispcp
? maradns/mararc.orig
? openoffice/dictionary.lst
? openoffice/dictionary.lst.old
? pam.d/imap
? pam.d/pop3
? passwd-.orig
? passwd.orig
? php5/conf.d/imap.ini
? php5/conf.d/mcrypt.ini
? php5/conf.d/mhash.ini
? postgrey/whitelist_clients
? postgrey/whitelist_recipients
? proftpd/ispcp/root_domain.conf
? proftpd/proftpd.conf.orig
? rkhunter.conf
? sasldb2
? shadow-.orig
? shadow.orig
Zainstalowałem apache2-mpm-preforki i zużycie ramu wróciło do normy, apache i MySQL się uruchamiają i zostaje jeszce 170mb ramu. Tylko, że jak próbuje wejść na stronę to:
Not Found
The requested URL / was not found on this server. was not found on this server.
Konfiguracja apache2 w sites-available jest poprawna, sprawdziłem, jakieś pomysły ?
Dobra, postawiłem apache2 na nogi, no prawie bo podczas wchodzenia na stronę dostaje:
</h1>
<h1>Forbidden[/b]
You don't have permission to access /index.php on this server.
logi z apache2/error.log
[Wed Oct 14 17:56:12 2009] [notice] caught SIGTERM, shutting down
[Wed Oct 14 17:56:16 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Wed Oct 14 17:56:17 2009] [notice] Apache/2.2.3 (Debian) mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming normal$
[Wed Oct 14 18:26:54 2009] [error] [client 62.55.104.207] File does not exist: /var/www/robots.txt
[Wed Oct 14 18:49:22 2009] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Wed Oct 14 18:49:24 2009] [notice] Apache/2.2.3 (Debian) mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) configured -- resuming normal$
Będę bardzo wdzięczny za wszelkie wskazówki.
Not Found
Nie bardzo jest poprawna skoro wywala coś takiego.
Sprawdź na co jest ustawione jako DirectoryIndex i czy ten plik jest w ścieżce wskazywanej przez DocumenRoot.
</h1>
<h1>Forbidden[/b]
chmod 0644 index.php
Tam jest oki,
ServerAdmin adres email
ServerName nazwa domenyl
DocumentRoot /var/www/katalog/
<Directory />
	Options FollowSymLinks
	AllowOverride None
</Directory>
<Directory /var/www/katalog/>
	Options Indexes FollowSymLinks MultiViews
	AllowOverride All
	Order allow,deny
	allow from all
	RewriteEngine on
	# This directive allows us to have apache2's default start page
	# in /apache2-default/, but still have / go to the right place
	# RedirectMatch ^/$ /apache2-default/
</Directory>
Nie było za to sites-enabled, zrobiłem powiązanie z sites-available i teraz wyskakuje to
Forbidden
chmody katalogów są na 755,
Logi z apache2/error.log które przedstawiłem post wyżej mówią coś komuś, bo mi nie bardzo;/
Są, ale dalej to samo
Tam jest oki,
<Directory />
	AllowOverride None
</Directory>
	AllowOverride All
	Order allow,deny
	allow from all
	RewriteEngine on
</Directory>
Forbidden
chown www-data:www-data /var/www/* -R
find /var/www/ -type d -exec chmod 0755 {} \;
find /var/www/ -type f -exec chmod 0644 {} \;
I musi działać, nie ma chuja we wsi.
Niestety dalej:
Skoro to nie chmody, to co to może być?
Niestety dalej:
A na pewno sprawdzasz właściwego hosta wirtualnego? Jeszcze może być kwestia konfiguracji dostępu w httpd.conf w dyrektywach Limit albo Directory za pomocą Deny from All np, ale mało prawdopodobne.
1. PHP działa tam jako moduł czy jako cgi (ew. fastcgi)?
2. Sprawdź czy da się otworzyć plik nie-php - np. index.html
3. Sprawdź czy nie masz tam pliku .htaccess
4. wykonaj: tail -n 20 access.log w katalogu z logami i pokaż zawartość
5. wykonaj: telnet www.nazwategoserwera.pl 80
A potem wpisz:
GET / HTTP:1.0
A potem dwa razy spacja. Wklej wynik.
A potem wpisz:
GET / HTTP:1.0
1) Jako moduł
2) index.html da się
3) Mam, nic podejrzanego nie widzę, :
<IfModule !mod_rewrite.c>
# ugly ugly hack to detect missing mod_rewrite
# RedirectMatch must be to an absolute destination, so forces 500 error...
ErrorDocument 500 "Elgg error: Apache does not have mod_rewrite loaded. Please check your Apache setup."
RedirectMatch 302 .* index.php
</IfModule>
<Files "htaccess_dist">
order allow,deny
deny from all
</Files>
# Don't listing directory
Options -Indexes
# Follow symbolic links
Options +FollowSymLinks
# Default handler
DirectoryIndex index.php
# Turn on expiry
<IfModule mod_expires.c>
ExpiresActive On
ExpiresDefault "access plus 10 years"
</IfModule>
# php 4, apache 1.x
<IfModule mod_php4.c>
ErrorDocument 500 "Elgg error: Elgg does not support PHP 4."
</IfModule>
# php 4, apache 2
<IfModule sapi_apache2.c>
</IfModule>
# php 5, apache 1 and 2
<IfModule mod_php5.c>
# default memory limit to 64Mb
php_value memory_limit 64M
# to make sure register global is off
php_value register_globals 0
# max post size to 60Mb
php_value post_max_size 60388608
# upload size limit to 60Mb
php_value upload_max_filesize 60242880
# hide errors, enable only if debug enabled
php_value display_errors 0
</IfModule>
# Turn on mod_gzip if available
<IfModule mod_gzip.c>
mod_gzip_on yes
mod_gzip_dechunk yes
mod_gzip_keep_workfiles No
mod_gzip_minimum_file_size 1000
mod_gzip_maximum_file_size 1000000
mod_gzip_maximum_inmem_size 1000000
mod_gzip_item_include mime ^text/.*
mod_gzip_item_include mime ^application/javascript$
mod_gzip_item_include mime ^application/x-javascript$
# Exclude old browsers and images since IE has trouble with this
mod_gzip_item_exclude reqheader "User-Agent: .*Mozilla/4\..*\["
mod_gzip_item_exclude mime ^image/.*
</IfModule>
## Apache2 deflate support if available
## Important note: mod_headers is required for correct functioning across proxies.
<IfModule mod_deflate.c>
AddOutputFilterByType DEFLATE text/html text/plain text/xml text/css text/javascript application/javascript application/x-javascript
BrowserMatch ^Mozilla/4 gzip-only-text/html
BrowserMatch ^Mozilla/4\.[0678] no-gzip
BrowserMatch \bMSIE !no-gzip
<IfModule mod_headers.c>
Header append Vary User-Agent env=!dont-vary
</IfModule>
# The following is to disable compression for actions. The reason being is that these
# may offer direct downloads which (since the initial request comes in as text/html and headers
# get changed in the script) get double compressed and become unusable when downloaded by IE.
SetEnvIfNoCase Request_URI action\/* no-gzip dont-vary
SetEnvIfNoCase Request_URI actions\/* no-gzip dont-vary
</IfModule>
# Configure ETags
<FilesMatch "\.(jpg|jpeg|gif|png|mp3|flv|mov|avi|3pg|html|htm|swf){:content:}quot;>
FileETag MTime Size
</FilesMatch>
<IfModule mod_rewrite.c>
RewriteEngine on
# If Elgg is in a subdirectory on your site, you might need to add a RewriteBase line
# containing the path from your site root to elgg's root. e.g. If your site is
# http://example.com/ and Elgg is in http://example.com/sites/elgg/, you might need
#RewriteBase /sites/elgg/
# here, only without the # in front.
# If you're not running Elgg in a subdirectory on your site, but still getting lots
# of 404 errors beyond the front page, you could instead try:
#RewriteBase /
RewriteCond %{HTTP_HOST} ^www.ibochnia.pl
RewriteRule ^(.*)$ http://ibochnia.pl/$1 [R=permanent,L]
RewriteRule ^action\/([A-Za-z\_\-\/]+)$ engine/handlers/action_handler.php?action=$1
RewriteRule ^export\/([A-Za-z]+)\/([0-9]+)$ services/export/handler.php?view=$1&guid=$2
RewriteRule ^export\/([A-Za-z]+)\/([0-9]+)\/$ services/export/handler.php?view=$1&guid=$2
RewriteRule ^export\/([A-Za-z]+)\/([0-9]+)\/([A-Za-z]+)\/([A-Za-z0-9\_]+)\/$ services/export/handler.php?view=$1&guid=$2&type=$3&idname=$4
RewriteRule ^\_css\/css\.css$ _css/css.php
RewriteRule ^pg\/([A-Za-z0-9\_\-]+)\/(.*)$ engine/handlers/pagehandler.php?handler=$1&page=$2
RewriteRule ^pg\/([A-Za-z0-9\_\-]+)$ engine/handlers/pagehandler.php?handler=$1
RewriteRule xml-rpc.php engine/handlers/xml-rpc_handler.php
RewriteRule mt/mt-xmlrpc.cgi engine/handlers/xml-rpc_handler.php
RewriteRule ^tag/(.+)/?$ engine/handlers/pagehandler.php?handler=search&page=$1
</IfModule>
4)
123.125.66.90 - - [14/Oct/2009:21:22:43 +0200] "GET / HTTP/1.1" 403 325 "-" "Baiduspider+(+http://www.baidu.com/search/spider.htm)"
220.181.7.60 - - [14/Oct/2009:21:24:56 +0200] "GET / HTTP/1.1" 403 325 "-" "Baiduspider+(+http://www.baidu.com/search/spider.htm)"
77.45.162.199 - - [14/Oct/2009:21:26:34 +0200] "GET /index.php HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:26:38 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:26:40 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:26:45 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:41:19 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:41:20 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:41:30 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:45:14 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:45:22 +0200] "GET /html.index HTTP/1.1" 404 322 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:45:31 +0200] "GET /index.html HTTP/1.1" 200 - "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:45:36 +0200] "GET /index.php HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:49:11 +0200] "GET /index.php HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:49:12 +0200] "GET /index.php HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:49:13 +0200] "GET /index.php HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:49:21 +0200] "GET /index.html HTTP/1.1" 200 - "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
77.45.162.199 - - [14/Oct/2009:21:49:26 +0200] "GET / HTTP/1.1" 403 325 "-" "Mozilla/5.0 (X11; U; Linux i686; pl-PL; rv:1.9.0.14) Gecko/2009090216 Ubuntu/9.04 (jaunty) Firefox/3.0.14"
66.249.71.214 - - [14/Oct/2009:21:50:23 +0200] "GET /pg/messageboard/alicja HTTP/1.1" 403 347 "-" "Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"
5)
Escape character is '^]'.
GET / HTTP:1.0
HTTP/1.1 403 Forbidden
Date: Wed, 14 Oct 2009 20:06:02 GMT
Server: Apache/2.2.3 (Debian) mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25)
Content-Length: 325
Connection: close
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>403 Forbidden</title>
</head><body>
<h1>Forbidden</h1>
<p>You don't have permission to access /index.php
on this server.</p>
<hr>
<address>Apache/2.2.3 (Debian) mod_ruby/1.2.6 Ruby/1.8.5(2006-08-25) Server at nazwa Port 80</address>
</body></html>
Connection closed by foreign host.
moduł php apache? iptable?
Jesteś pewien, że php działa jako moduł Apache? Bo po server-signature to jest więcej niż wątpliwe.
Tu nic o załadowanym PHP nie ma...
Może ispcp zmienił ci konfigurację bądź cgi, bądź suphp i nie może dostać się z jakichś powodów do wrappera?
Dokładnie, powyciskał swoje moduły np. suphp zamienił z suexec.
Doszedłem już do Internal Server Error więc jest progres.
Log z apache/error.log:
[Thu Oct 15 00:23:41 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/index.php" is smaller than min_uid
[Thu Oct 15 00:23:41 2009] [error] [client 77.64.162.199] Premature end of script headers: index.php
[Thu Oct 15 00:26:45 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/index.php" is smaller than min_uid
[Thu Oct 15 00:26:45 2009] [error] [client 77.64.162.199] Premature end of script headers: index.php
[Thu Oct 15 00:27:07 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/index.php" is smaller than min_uid
[Thu Oct 15 00:27:07 2009] [error] [client 77.64.162.199] Premature end of script headers: index.php
[Thu Oct 15 00:31:16 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/index.php" is smaller than min_uid
[Thu Oct 15 00:31:16 2009] [error] [client 77.64.162.199] Premature end of script headers: index.php
[Thu Oct 15 00:31:17 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/index.php" is smaller than min_uid
[Thu Oct 15 00:31:17 2009] [error] [client 77.64.162.199] Premature end of script headers: index.php
[Thu Oct 15 00:37:00 2009] [error] [client 220.181.7.19] SoftException in Application.cpp:296: UID of script "/var/www/katalog/index.php" is smaller than min_uid
[Thu Oct 15 00:37:00 2009] [error] [client 220.181.7.19] Premature end of script headers: index.php
[Thu Oct 15 00:26:45 2009] [error] [client 77.65.162.199] Premature end of script headers: index.php
[Thu Oct 15 00:27:07 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/ind$
[Thu Oct 15 00:31:16 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/ind$
[Thu Oct 15 00:31:17 2009] [error] [client 77.64.162.199] SoftException in Application.cpp:296: UID of script "/var/www/katalog/ind$
Nie ułatwiasz sprawy - co znaczy że doszedłeś? Zmieniłeś konfigurację na mod_php czy naprawiłeś fastcgi? Jeśli to drugie, to
za Internal Server Error odpowiada plik .htaccess, a konkretnie wpisy konfiguracyjne modułu php, bo apache wtedy ich
nie rozumie i wywala pięćsetkę.
Z odpowiedzi, którą pokazałeś, wynika, że nie pracuje to w trybie mod_php, a suphp.
Tak więc zmień ownera plików na jakiegoś normalnego użytkownika (nie root'a, nie www-data, tylko zwykłe konto) i powinno działać.
