lord101
Problem z mysql, nie działa
Po restarcie serwera mysqld już nie wstało, wszystko pod panelem direcadmin. Logi mi nic nie mówią. Ktoś jest w stanie je rozczytać?
140520 17:37:59 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/data
140520 17:37:59 [ERROR] Can't find messagefile '/usr/share/mysql/english/errmsg.sys'
140520 17:37:59 [Note] Plugin 'FEDERATED' is disabled.
140520 17:37:59 InnoDB: The InnoDB memory heap is disabled
140520 17:37:59 InnoDB: Mutexes and rw_locks use InnoDB's own implementation
140520 17:37:59 InnoDB: Compressed tables use zlib 1.2.3
140520 17:37:59 InnoDB: Using Linux native AIO
140520 17:37:59 InnoDB: Initializing buffer pool, size = 128.0M
140520 17:37:59 InnoDB: Completed initialization of buffer pool
InnoDB: The first specified data file ./ibdata1 did not exist:
InnoDB: a new database to be created!
140520 17:37:59  InnoDB: Setting file ./ibdata1 size to 10 MB
InnoDB: Database physically writes the file full: wait...
140520 17:37:59  InnoDB: Log file ./ib_logfile0 did not exist: new to be created
InnoDB: Setting log file ./ib_logfile0 size to 5 MB
140520 17:37:59  InnoDB: Log file ./ib_logfile1 did not exist: new to be created
InnoDB: Setting log file ./ib_logfile1 size to 5 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: 127 rollback segment(s) active.
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
140520 17:37:59  InnoDB: Waiting for the background threads to start
140520 17:38:00 InnoDB: 1.1.5 started; log sequence number 0
140520 17:38:00 [ERROR] Aborting
140520 17:38:00  InnoDB: Starting shutdown...
140520 17:38:01  InnoDB: Shutdown completed; log sequence number 1595675
140520 17:38:01 [Note]
140520 17:38:01 mysqld_safe mysqld from pid file /usr/local/mysql/data/s2.pid ended
140520 17:38:01 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/data
140520 17:38:01 [ERROR] Can't find messagefile '/usr/share/mysql/english/errmsg.sys'
140520 17:38:01 [Note] Plugin 'FEDERATED' is disabled.
140520 17:38:01 InnoDB: The InnoDB memory heap is disabled
140520 17:38:01 InnoDB: Mutexes and rw_locks use InnoDB's own implementation
140520 17:38:01 InnoDB: Compressed tables use zlib 1.2.3
140520 17:38:01 InnoDB: Using Linux native AIO
140520 17:38:01 InnoDB: Initializing buffer pool, size = 128.0M
140520 17:38:01 InnoDB: Completed initialization of buffer pool
140520 17:38:02 InnoDB: highest supported file format is Barracuda.
140520 17:38:02  InnoDB: Waiting for the background threads to start
140520 17:38:03 InnoDB: 1.1.5 started; log sequence number 1595675
140520 17:38:03 [ERROR] Aborting
140520 17:38:03  InnoDB: Starting shutdown...
140520 17:38:03  InnoDB: Shutdown completed; log sequence number 1595675
140520 17:38:03 [Note]
140520 17:38:03 mysqld_safe mysqld from pid file /usr/local/mysql/data/s2.pid ended
Pomogła aktualizacja z 5.0 na 5.5 mysql jednak bazy danych zostały uszkodzone
Po to są backupy :)
Po to są backupy :)
Dlatego musiałem go wgrać ;)
Jednak nadal nie wiem co było tego powodem. Większość tabel posiekało.
