Gość IStreamPL
rtorrent nie pobiera / nie widzi torrentów.
Gość IStreamPL
Witam, zainstalowałem rtorrent, skonfigurowałem go i niestety po wrzuceniu dowolnego pliku torrent, on go nie widzi.
Log z .rtorrent.rc
# This is an example resource file for rTorrent. Copy to
# ~/.rtorrent.rc and enable/modify the options as needed. Remember to
# uncomment the options you wish to enable.
# Maximum and minimum number of peers to connect to per torrent.
#min_peers = 0
#max_peers = 0
# Same as above but for seeding completed torrents (-1 = same as downloading)
#min_peers_seed = 0
#max_peers_seed = 0
# Maximum number of simultanious uploads per torrent.
#max_uploads =0
# Tu ustawiamy prędko¶ć wysyłania (upload) i pobierania (download) 0=bez ograniczeń
# Zalecana prędko¶ć uploadu to 75% maksymalnej prędko¶ci ł±cza
download_rate = 0
upload_rate = 0
# Domy¶lny katalog do zapisu pobranych plików:
directory = /home/root/rtorrent/pobrane
#Katalog gdzie zapisywana będzie sesja
session = ~/rtorrent/.session
# Przeszukiwanie danego katalogu na obecno¶ć torrentów do pobrania
# Zatrzymywanie gdy torrent (plik ziarna) zostanie usuniety (nie sprawdzone - zahaszowane)
schedule = watch_directory,5,5,load_start=/home/root/rtorrent/pliki-ziarna/*.torrent
#schedule = untied_directory,5,5,stop_untied=/home/root/rtorrent/pliki-ziarna/*.torrent
# Close torrents when diskspace is low.
#schedule = low_diskspace,5,60,close_low_diskspace=100M
# Stop torrents when reaching upload ratio in percent,
# when also reaching total upload in bytes, or when
# reaching final upload ratio in percent.
# example: stop at ratio 2.0 with at least 200 MB uploaded, or else ratio 20.0
#schedule = ratio,60,60,stop_on_ratio=200,200M,2000
# The ip address reported to the tracker.
#ip = 127.0.0.1
#ip = rakshasa.no
# The ip address the listening socket and outgoing connections is
# bound to.
#bind = 127.0.0.1
#bind = rakshasa.no
# Port range to use for listening.
port_range = 10000-20000
# Start opening ports at a random position within the port range.
port_random = yes
# Check hash for finished torrents. Might be usefull until the bug is
# fixed that causes lack of diskspace not to be properly reported.
check_hash = yes
# Set whetever the client should try to connect to UDP trackers.
use_udp_trackers = yes
# Alternative calls to bind and ip that should handle dynamic ip's.
#schedule = ip_tick,0,1800,ip=rakshasa
#schedule = bind_tick,0,1800,bind=rakshasa
# Encryption options, set to none (default) or any combination of the following:
# allow_incoming, try_outgoing, require, require_RC4, enable_retry, prefer_plaintext
# The example value allows incoming encrypted connections, starts unencrypted
# outgoing connections but retries with encryption if they fail, preferring
# plaintext to RC4 encryption after the encrypted handshake
# encryption = allow_incoming,enable_retry,prefer_plaintext
# Do not modify the following parameters unless you know what you're doing.
# Hash read-ahead controls how many MB to request the kernel to read
# ahead. If the value is too low the disk may not be fully utilized,
# while if too high the kernel might not be able to keep the read
# pages in memory thus end up trashing.
#hash_read_ahead = 10
# Interval between attempts to check the hash, in milliseconds.
#hash_interval = 100
# Number of attempts to check the hash while using the mincore status,
# before forcing. Overworked systems might need lower values to get a
# decent hash checking rate.
#hash_max_tries = 10
# Max number of files to keep open simultaniously.
#max_open_files = 128
# Number of sockets to simultaneously keep open.
#max_open_sockets = <no default>
# Example of scheduling commands: Switch between two ip's every 5
# seconds.
#schedule = "ip_tick1,5,10,ip=torretta"
#schedule = "ip_tick2,10,10,ip=lampedusa"
# Remove a scheduled event.
#schedule_remove = "ip_tick1"
Po wrzuceniu plików .torrent odpalam komendą
screen rtorrent poczym sobie tak stoi
Wrzucałem różne configi ale dalej to samo.
Prosiłbym o pomoc.
Wrzucasz go tu oczywiście?
Co to w ogóle jest za folder, home roota standardowo ma ścieżkę /root, a nie żadne /home/root więc upewnij się, że rzeczywiście ta linijka jest dobra.
Gość IStreamPL
Ups ale byka zrobiłem, zapomniałem home skasować więc pewnie dlatego.
Już poprawiam i napiszę jak wyniki.
/ edit
już działa dzięki za poprawkę.
Edytowano przez IStreamPL (zobacz historię edycji)
Zaznaczę jeszcze, że używanie roota jako "użytkownika" to kiepski pomysł.
