Gość IStreamPL
Problem z serwerem
Gość IStreamPL
Witam, mam mały problem, otoż wchodząc na stronę pobiera mi się pliczek pobrane.php
http://178.19.104.75
O co chodzi? Reinstalowałem apache2 jednak dalej to samo.
Gość IStreamPL
Tzn działał. Nie konfigurowałem tego własciwie tylko komenda
apt-get install apache2
wgranie rapidleecha do /var/www
i wszystko działało przez jakieś 2 tygodnie.
Dopiero wczoraj pojawił się problem.
Wgrałem rl też na VPSa i też to samo.
Apache2 śmiga
http://178.19.108.242
lecz rl już nie
http://178.19.108.242/rapidleech
libapache2-mod-php5
a2enmod php5
na koniec
/etc/init.d/apache2 restart
Gość IStreamPL
InnoDB: Unable to lock ./ibdata1, error: 11
InnoDB: Check that you do not already have another mysqld process
InnoDB: using the same InnoDB data or log files.
130209 20:58:15 InnoDB: Unable to open the first data file
InnoDB: Error in opening ./ibdata1
130209 20:58:15 InnoDB: Operating system error number 11 in a file operation.
InnoDB: Error number 11 means 'Resource temporarily unavailable'.
InnoDB: Some operating system error numbers are described at
InnoDB: Could not open or create data files.
InnoDB: If you tried to add new data files, and it failed here,
InnoDB: you should now edit innodb_data_file_path in my.cnf back
InnoDB: to what it was, and remove the new ibdata files InnoDB created
InnoDB: in this failed attempt. InnoDB only wrote those files full of
InnoDB: zeros, but did not yet use them in any way. But be careful: do not
InnoDB: remove old data files which contain your precious data!
130209 20:58:15 [ERROR] Plugin 'InnoDB' init function returned error.
130209 20:58:15 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
insserv: warning: script 'K01mysqld' missing LSB tags and overrides
insserv: warning: script 'K01directadmin' missing LSB tags and overrides
insserv: warning: script 'K01startips' missing LSB tags and overrides
insserv: warning: script 'K01da-popb4smtp' missing LSB tags and overrides
insserv: warning: script 'mysqld' missing LSB tags and overrides
insserv: warning: script 'startips' missing LSB tags and overrides
insserv: warning: script 'da-popb4smtp' missing LSB tags and overrides
insserv: warning: script 'directadmin' missing LSB tags and overrides
Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed!
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: bĹÄ
d przetwarzania mysql-server-5.1 (--configure):
podproces zainstalowany skrypt post-installation zwrĂłciĹ kod bĹÄdu 1
configured to not write apport reports
dpkg: problemy z zaleĹźnoĹiami uniemoĹźliwiajÄ
skonfigurowanie mysql-server:
mysql-server zaleĹźy od mysql-server-5.1; jednakĹźe:
Pakiet mysql-server-5.1 nie jest jeszcze skonfigurowany.
dpkg: bĹÄ
d przetwarzania mysql-server (--configure):
problemy z zaleĹźnoĹiami - pozostawiony nieskonfigurowany
^[[?6c^[[?6cWystÄ
piĹy bĹÄdy podczas przetwarzania:
mysql-server-5.1
mysql-server
a można jakoś to usunąc? przez mysql-server nie mogę zainstalować tej paczki libapache2-mod-php5
na dedyku :/
