mateusz232
pomoc w malej przerobce uploadu ;)
Index.php wygląda tak:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>nulled2.net Uploader</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
<form enctype="multipart/form-data" action="upload.php" method="POST">
 <p align="center"><font size="2" face="Arial, Helvetica, sans-serif"><strong>
<input type="hidden" name="MAX_FILE_SIZE" value="100000000" />
<img src="logo.jpg" width="500" height="100"> </strong></font> </p>
 <div align="center">
<table width="42%" border="0">
  <tr>
	<td><div align="left"><font color="#333333" size="1" face="Tahoma"> Please
		click browse and select the file you want to upload. The file must
		be less then <strong> <?
ini_set('upload_max_filesize', 1000);
echo ini_get('upload_max_filesize');
?> </strong></font></div></td>
  </tr>
  <tr>
	<td><div align="center"><font size="2" face="Arial, Helvetica, sans-serif"><strong>
		<input name="uploadedfile" type="file" size="80" />
  </tr>
  <tr>
	<td height="61">
<p><font size="2" face="Arial, Helvetica, sans-serif"><strong>
		  <input name="submit" type="submit" value="Upload Selected File" />
		  </strong></font></p>
	  </div></td>
  </tr>
</table>
 </div>
 <div align="center"><strong><font color="#333333" size="1.5" face="Tahoma">xxx.pl</font></strong></div>
</strong></font><font size="2" face="Arial, Helvetica, sans-serif"></font></p>
 </form>
</body>
</html>
plik upload.php wyglada tak:
<title>nulled2.net Upload Successful</title>
$target_path = "files/";
$target_path = $target_path . basename( $_FILES['uploadedfile']['name']);
if(move_uploaded_file($_FILES['uploadedfile']['tmp_name'], $target_path)) {
<p align="center"><font size="2" face="Arial, Helvetica, sans-serif"><strong><img src="logo.jpg" width="500" height="100">
 <table width="66%" border="0">
<tr>
	  <p><font color="#333333" size="2" face="Tahoma"><strong>Your file has
		been uploaded successfuly!</strong> To download your file follow this
		link:</font></p>
	  <p><font color="#333333" size="2" face="Tahoma"><a href="http://<? echo $_SERVER["SERVER_NAME"]?>/files/<? echo basename( $_FILES['uploadedfile']['name']); ?>">http://<? echo $_SERVER["SERVER_NAME"]?>/files/<? echo basename( $_FILES['uploadedfile']['name']); ?></a></font></p>
	  </div></td>
</tr>
 </table>
 <p><strong><font color="#333333" size="1.5" face="Tahoma">xxx.pl</font></strong></p>
</div>
<div align="center"></div>
} else{
header("Location: fail.php");
Jak dodać kodowanie by po zauploadowaniu pliku, ścieżka do pliku była w jakimś kodowaniu. Problemem jest to oczywiście ze pliki beda nakładać się gdyż wygląda to w tej chwili tak :http/www.xxxxx.pl/file/file.jpg a chce zeby zamiast /file/ było jakieś kodowanie
md5(ip usera i czas) ? ;)
ścieżkę do folderu gdzie ma być zapisany plik ustalasz w
już prędzej np tak:
$target_path = 'files/' . md5(time()) . '/';
tylko wcześniej wypadałoby utworzyć ten katalog ;)
Mam kolejne pytanie gdzyz teraz kodowanie dodaje sie do pliku wrzuconego nie do folderu
2f6066df40d47345bd0531532632618e_putty.exe
Była by możliwa zmiana żeby md5 było dodane jakoś do folderu ? i z kazdym razem tworzył sie nowy folder ? lub jakos inaczej to zastapic ? gdyz zmiana nazwy pliku uprzykrzy troche zycie ;(
niebezpieczny ten Twoj skrypt :)
a niby dlaczego ? :)
zerknij na post #4.... tamten kod kopiuje plik do folderu z fajną nazwą.
Jak dodałem ta linijkę to zmienia mi nazwę pliku nie folderu :)
2)
1 - wrzuć sobie tam jakiś skrypt php i spróbuj odpalić ;-)
2 - heh, możesz dać np 'files_' . md5(time()) . '/'; i wtedy będziesz mieć masę folderów files_*
Ok juz zrobione tworzy sie nowy folder i dodaje plik :mellow:
teraz jedyne czego nie wiem to jak przerobić ta linijkę
żeby wyświetlała dokładną lokalizacje pliku ?
to dodałem do upload.php
$target_path = 'files_' . md5(time()) . '/';
mkdir ('/home/xpl/public_html/upload/'.$target_path, 0777);
zapisz sobie md5(time()) do jakiejś zmiennej i zagadaj do niej podczas generowania urla i pokazywania jego :mellow:
