mke
VPS i mod_suphp problem z uprawnieniami
Witam, jestem calkowicie nowy w temacie, zlece za pieniadze rozwiazanie mojego problemu, sprawa jest raczej pilna, mam VPS'a (centOS 4.2) za granica i mam problem z uprawnieniami który pojawia sie przy probie postawienia strony opartej na Joomla
A lot of people have problems with different PHP softwares like Joomla, different Gallery softwares, especially where need to upload pictures. Why? Because now in a new settings, PHP will work as apache:apache user and any files uploaded via a web interface will get this user rights. Any files uploaded via FTP clients, will get the domain ownership. SO, if you for example want to get all picture files added via WEB INTERFACE, you cannot download or overwrite via FTP because the file rights. Also on install a lot of people need to setup folders to 777 rights to uload in it.
Chodzi o mi o to zeby rozwiazac problem z uprawnieniami za pomoca modulu suphp, chcialbym aby modul dzialal dla wszystkich maszyn wirtualnych
http://www.suphp.org/Documentation-Module-...llation.en.html
Mozliwosci rozwiazania tego zawieraja ponizsze linki
http://blog.stuartherbert.com/php/2008/01/...-shared-server/
lub
w punkcie 18 http://www.web-hosting-control-panel-addon...cated_Server/6/
sam modul jest juz nawet zainstalowany ale nie moge dojsc jak to skonfigurowac
rpm -ql mod_suphp-0.6.2-1.el4.rf
/etc/httpd/conf.d/suphp.conf
/etc/suphp.conf
/usr/lib/httpd/modules/mod_suphp.so
/usr/sbin/suphp
/usr/share/doc/mod_suphp-0.6.2
/usr/share/doc/mod_suphp-0.6.2/AUTHORS
/usr/share/doc/mod_suphp-0.6.2/COPYING
/usr/share/doc/mod_suphp-0.6.2/ChangeLog
/usr/share/doc/mod_suphp-0.6.2/NEWS
/usr/share/doc/mod_suphp-0.6.2/README
/usr/share/doc/mod_suphp-0.6.2/doc
/usr/share/doc/mod_suphp-0.6.2/doc/CONFIG
/usr/share/doc/mod_suphp-0.6.2/doc/INSTALL
/usr/share/doc/mod_suphp-0.6.2/doc/LICENSE
/usr/share/doc/mod_suphp-0.6.2/doc/README
/usr/share/doc/mod_suphp-0.6.2/doc/apache
/usr/share/doc/mod_suphp-0.6.2/doc/apache/CONFIG
/usr/share/doc/mod_suphp-0.6.2/doc/apache/INSTALL
/usr/share/doc/mod_suphp-0.6.2/doc/apache/README
/usr/share/doc/mod_suphp-0.6.2/doc/suphp.conf-example
Trochę nie ten dział.
p.s. dlaczego suphp ?
Jaki inne modul lub rozwiazanie mozna zastosowac na ten problem?
Hm najprostsze to zamiast preforka użyć itk, choć niektórzy mogą mówić, że to jeszcze uznawane za w fazie testowej, to ja nie zauważyłem problemów, choć maszyna na której to jest ma bardzo malutkie obciążenie.
http://mpm-itk.sesse.net/
Drugi sposób to suexec+php jako fastcgi które chyba jest najpopularniejszym rozwiązaniem.
